Creates an OSPFv3 area.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
Area 0.0.0.0.
Area 0.0.0.0 does not need to be created. It exists by default.
The following command creates a non-backbone OSPFv3 area:
create ospfv3 area 1.2.3.4
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
